General question
bke
I was wondering sometimes when I put the motor half throttle the motor will rev high and then I put it back in nuetral and then I kcick it back into gear it won't do that again. I have 01 Mercury 125hp Any thoughts.
JB
Re: General question
Check prop for ventilation or spun hub.
bke
How do you check those twp things?
JB
Prop ventilation is when the prop grabs air from the surface and spins in the foam without producing thrust. It is usually caused by the motor being mounted too high or trimmed out too far.
To check for a spun hub mark a line through the end of the prop where it is bolted on. Run her until you get the high rev, then look to see if the outer part of the hub has slipped from the inner part. Most prop shops can re-hub for a lot less than a new prop.
bke
I bet I have the motor trimmed to high.
pigeon laker
I have a Merc 115,I can trim my motor all the way up without losing traction.Should I be raising my motor higher on the transom?
bke
If it was my motor I would leave motor mounted where it is now.
