General Question
Status
Not open for further replies.
bigdaddy08302
I posted earlier about a Merc I may want to buy. Just in general terms what is the opinion of th 1985 Mercury 115?
SparkieBoat
Re: General Question
merc and omc made some real good motors from about 1983-1991..my favorite years for an ourboard
Chris1956
That '85 Merc 115HP inline six is a good design. It has the modern ign system. It is 99 Cu in and about 300# which makes it have a good HP to weight ratio. It has excellent midrange and top end power and speed. It is challenged a bit on low end power due to the lower displacement.
I recommend you inspect the engine wiring, check the compression and inspect the color of the gear oil. That motor is 26 years old, so it is not worth too much dollars, but can be worth a bit to the owner.
JB
Why ask the same question three times, bigdaddy?? It is very bad manners and violates our rules.
Status
