Re: Generator questions, help needed
What Bondo said, except I hate double mail plugs - I have the scares on my hand from one of them - burned down near to the bone and basically knocked me out for 18 hours - after shock and dance to end of cord, where if was finally ripped from my hand, I put ice on burn and went to bed. Woke up 18 hours later.<br /><br />I would rather you pull the main fuse panel out, or if you have a quick disconnect, through it. Then wire it directly to panel box. I know, it is more time and hassle, but it could save a life - yours or your kids.<br /><br />Ours here in the Training Centre is perminantly wired to an "alternate source" quick disconnect. That way when the electric goes off (and it does at least once a week), we only have to throw the switch to neutral, start generator, then throw switch to Generator. Turn on the lights that are wired in before the dissconnect, so when the electric comes back on, we are know it, and we are set. We have a 100kVA gen set, but then we are running central air, a computer lab, etc. Need a bit more juice than the average house.<br /><br />5.5kVA should be plenty to run most of your house. When you pull the mains, also throw off the breakers to the washer, drier, etc. Anything you don't need. That way you won't run the risk of an accidental overload.
