Generator
Bobobob
I was wondering if there is a generator for an RDSL-24L 1962 40hp Johnson and if so where I might find one?
Chris1956
Re: Generator
Rob, The electric start version of that motor came with a small automotive-style generator, which was belt driven and bolted on the to block on the opposite side of the starter. It had an external voltage regulator (like early sixties cars), which mounted in the transom-mounted electrical box.
You may find one, if you look hard enough. I recommend you invest in a good marine starting battery, and charge it up once a month, instead.
F_R
Re: Generator
Actually, it was an optional accessory available for the electric start models. All 40 horsepower electric shift models had generators as standard equipment.
Bobobob
Re: Generator
Thanks, Mine is an electric start model manual shift, I only inquired about it because I will be running a livewell in my boat for a few derbys comming up and I just don't want to run the battery down when I'm out on the rivers and lakes. I have a fresh Canadian Tire Nautilus Battery with 1000 Amp crank. Would a Solar panel be better then trying to find a generator?
Silvertip
Re: Generator
Your boat is not large enough to house a solar panel large enough to provide any significant charge. The cost of a solar charger that would be big enough, even if you had room for it, would send your wallet into shock. It's not an option. Install a second deep cycle battery. It would operate a live for days.
F_R
Re: Generator
The generator puts out 10 amps maximum. But it has to be running 2000 rpm before it puts out anything. Since maintaining a charge depends on what you are taking out of the battery versus what you are putting back in, it would depend on how much you run at about half throttle. Simple math says that 10 amps X 5 hours = 50 amp hours. How much does your livewell pump draw? However, anything you put back in is better than nothing.
