Gettin Ready to Paint your boat..., You might want to check this out!!
Woodonglass
I just saw this from a guy on Fiberglassics. Looks interesting. I have NOT used it so I do NOT have any experience with it so cannot say if it is Good, Bad or Indifferent. Just thought I'd pass it a long in case someone out there has used it and could help us out with their opinion. I might get some and try it on my Trailer painting in a couple of weeks.
Clausen ALL-U-NEED? ULTIMATE HI-BUILD Polyester Primer-Surfacer-Sealer
Email this page Print this page
Larger View
$45.00
This primer/sealer does it all - it's ALL YOU NEED!
Unique all-in-one formula replaces metal prep, etching primer, primer-surfacer, and sealer. Self-etching to all metals, fiberglass, and wood. Compatible with all paints and primers. Contains 86% solids for high build and sands easy with no shrinkage. Waterproof formula is zinc-enriched and isocyanate-free. No re-coat time. No sanding prior to re-coating. Eliminate steps! Apply this over your properly-prepared surface and you are ready for base coat. Eliminate guesswork and buy the primer/sealer that does it all. Includes hardener. Light gray. Reduce with acetone or quality lacquer thinner if needed.
Available in quart and gallon.
BWT
Re: Gettin Ready to Paint your boat..., You might want to check this out!!
Sounds interesting; I've never used it before but would be curious to see if it can live up to it's claims!
lakelover
Almost sounds too good to be true.;)
Curious if anyone has tried it.
AList233
Clausen Products have been around the auto refinish industries for years. I've used their products and have had good sucess. Be interested in trying out this one!
