Getting a 70hp running again
Dennischaves
My boat came with a 70hp E70ELCNB
Now that i got the stringers and deck done
I need help getting the motor ready for next season
First off...The recipt for the motor says its an 83'
But when I check the model numbers it says its a 82'?
Also my motor has no tnt and there is no reverse lock
Is it supposed to have one?
Joe Reeves
E70ELCNB
E == Evinrude
70 = Horsepower
L == Long Shaft (20")
C == 8
N == 2
B == Factory run number, of no consequence
No Tilt/Trim on this model. Any engine with a Tilt/Trim unit would have a "T" in the model number. Seeing as how a PTT unit could not be installed easily on this model, it stands to reason that there would be no purpose to removing the manual Tilt/Lock mechanical apparatus... strange! Is the reverse lock rod in the holes in the transom brackets?
Many of the 82 models came with trim and tilt.------It was easy to retrofit the trim and tilt on them.------Pictures of your set-up today would help.------When installing a trim on those , the tilt aide / shock absorber was removed and the reverse lock was removed.----So is there a sngle cylinder installed on your motor now ?----It would be between the transom brackets.
Dennischaves
No Title
There was never a tnt on it
I got it from the original owner
Heres some pictures
Something is definatly missing there
Sorry about the poor picture quality
The motor is black and its dark outside
I did my best using a light
F_R
Methinks at one time it had a PTT kit installed, but it was removed and the original shock absorber parts reinstalled. But they didn't reinstall everything. The trail lock spring in the picture is supposed to be used with PTT. (According to the parts book)
Dennischaves
What parts do i need or does anyone have a picture of a 3cyl maybe i can make something....any ideas?
oldboat1
might help to get a look at a sister motor, or maybe some pics in the service manual (operator's manual might do it for the reverse lock).
Dennischaves
I was hoping someone coud snap a clear picture of what the assembly looks like
So maybe i could make something
I made a few calls tonight to people selling used parts on CL but no one has it
F_R
You would have to be pretty darn talented and have a shop full of tooling to make it. That thing holds it down in forward as well as reverse and withstands a heck of a lot of stress right before releasing if you hit an underwater obstruction.
The main parts on the iboats diagram that I posted above are 79, 81, 85, 89, and a bunch of bits and pieces that go with them.
Your location ?----Look for a used trim / tilt unit.-----You would be a lot happier with that.-----I have a bunch of that reverse lock stuff laying around, yes I do.-----Shipping cost may be a deterrant.
Dennischaves
Racerone: i tried sending you back a private message but its not working
I just checked my messages foung the parts locally for $20 but i have to pick them up tommorow first thing
Dennischaves
Ok next i plan on taking apart the carbs and rebuilding them and the water impeller
Is there anything else i should do to get the motor ready to use?
Dennischaves
Shopping around for parts there are so many options
Amazon,ebay,iboats and sierra are the parts the same or is there a diffrence?
For s couple dollars I dont want to have to do the job twice
Dennischaves
When I take the carbs off the motor am i going to have to do a link&sync after i reinstall them
Also does anyone put any sealent on the gasket between the carb and the block
Joe Reeves
No sealant anywhere on any gasket pertaining to a fuel system.... if anything, just oil!
Dennischaves
Ok thank you
And im just assuming take the carb linkages off without disrupting anything?
