So my 1958 Johnson 35hp is not running right. From what I have read on here, it sounds like it's running on only 1 cylinder. It idle's OK, not great at first but good enough to keep it from stalling. It idles better after running for 5 minutes.
I thought everything was OK so I take it out on the water and start it up, same sort of deal.I let it warm up a few minutes, then shift into forward--and it felt like it immediately wants to stall, so I give it a bit more throttle, now i'm at about 2/3 throttle and its just enough to get me moving about 5-6mph approx. I push it open to WOT, and all the motor does is gain a slight bit more RPM (maybe 200 more rpm?), my boat goes a couple MPH faster, but the motor is noticeably running rougher and vibrating more. The carb was recently serviced, as were the coils and points--has to be the plugs or wires I assume.
I have read that the simplest way to make sure both cylinders are firing OK is to run the motor in the bucket, and while its running, disconnect 1 of the 2 plugs. if the motor is operating correctly, it should still run on 1 plug, but run rougher--It should be a noticeable difference. If that cylinder was not firing and you pull the plug wire, I will not notice a difference when I unplug it. Likewise if that cylinder was the only one firing, and I unplug it--the motor will simply quit.
My questions are: Does this hurt the motor at all to do this? Also, if it turns out that both cylinders have spark--what else could cause the motor to run this badly? I know the high speed needle could play a part, but I believe it it relatively close to where it should be (I started at 1.25 turns out from closed and played with it from .75 turn to 1.75 turn, and still ran just as poorly. I did this on the lake while giving it almost full throttle). Could it be gas? The fuel tank had 1 year old/bad gas in it when I got it. I siphoned that out, filled it up with 2 gallons of fresh 87 octane and siphoned that out as well, then filled it up 100% (6 gallons) with new 89 octane at a 24-1 oil ratio. So I figured the gas is good--but I suppose there could have been an ounce or two of residual junk fuel that got mixed in with the new stuff.
I plan on testing the plugs tonight. Any thoughts? Thanks
