Getting Hot
VRMLN TR
I have a 2007 Volvo Penta 5.0L GL. It noticed the other day that it was running about 150 degrees when cruising along at 2800 to 3200 RPM's. When I get it up to full throttle the temp is rising to about 195 or 200. Then when I let off the temp takes a couple seconds and comes back down.
Could there be some blockage in the cooling system. or could it be an air leak somewhere?
bruceb58
Re: Getting Hot
When was the last time you changed the raw water pump impeller?
