tractorboy
- Jul 1, 2010
- 60
Hello, I have a 1990 sunbird i/o with an omc 4.3 and cobra outdrive. new to me last year. I know its got a new motor and PO said they replaced cables at time of engine replacement.
Its always been a little hard/stiff (noticeable) to get it into neutral from forward or reverse but not too bad at all. (more noticeable to get OUT of gears than it is to get INTO gear) rest of the throttle is perfectly smooth. Now its getting hard to get in and out of gear so Read here to check for cable binding. Which I did and didnt see anything. I lubed the cables and the joints best I could.
After researching im now seeing its most likely the ESA module...but a question.. is there a way to trouble shoot it to ensure thats it? and also how does this module know when to "kick in" and drop the idle? Im thinking there is something ont he cable that triggers or some sort of manual occurance that can also be check to ensure its being TOLD to activate...if that makes sense.
I also ask as in know there was an engine replacement and ive seen people say that people have zipped tied things that should be on it.
Todd
Thank you.
Todd
Thank you.
