Re: getting into gear help
Welcome aboard!!
I moved this to the I/O section, you posted in the Mercury OB forum.
There is an area where the clutch dogs are engaging that you need to move the shifter quickly through. If you are hearing a clunkety, rhythmic clicking sound then you are lingering there. What you are supposed to do is quickly move through that so you don't hear it. There is some slop built into the shift mechanism so you don't accelerate until well after completing a shift. You need to practice shifting faster and farther so that you don't hear that sound and she clunks firmly into gear. When you do it properly there will be no rhythmic sound and you will still be at idle speed. If these instructions solve it, then it is normal. If you can't deftly and quickly shift through the noise, then there may be an issue. Good luck!!
