getting ready for winter issue 3.0
yscrewu2
so i have a 3.0 volvo penta Omc cobra
every year i drain the petcocks and for some reason the manifold did not let out any water this year:confused:. why would that be:confused:? I didnt use it much this year but i didnt have any over heating issues
I tried taking a hanger and probing it around in there but still didnt get anything?
There should be water in there seeing i had it on the ears and running for a good 20 min right?
jerryjerry05
Re: getting ready for winter issue 3.0
Any water comming from the block?
What year,model?Always include that info.
Add it to your signature?
yscrewu2
1987 Bayliner and yes there was water that came out of the block
Lou C
What exactly do you have, an OMC Cobra drive and a Volvo Penta engine, or what? I know the 4 cyl Volvos used to have closed cooling but are you sure you removed the drain plug on the manifold, or maybe just a plug that does not go into a water passage. I'm guessing that by the year (87) you have an OMC Cobra 4 cyl engine raw water cooled....
aerobat
Master Chief Petty Officer
dig in a small screwdriver or something solid in the petcock opening of the manifold. BET there is water in but maybe this year you have clogged the petcock relativly solid.
