getting to rings on an 82 V6 150 Mercury OB
dwjohnson
All six cylinders at 105-110 compression and runs very well w/o a load but no acceleration in water. Found head gaskets leaking. Cylinder walls are clean and smooth. Can slightly move piston head inside of cylinder. Can see rings.Feeler gauges around .003 and cannot pass thru w/o a lot of effort.Question is can I re-ring the pistons w/o disassembling the block? Can the rod bearing end caps nuts be reached if the reed valve block is removed? Have cleaned and kitted the carbs, floats were off. Thought of just replacing the head and cover gaskets but if the rings can be reached....<br />Thanks, Doug in Chas., SC
JB
Re: getting to rings on an 82 V6 150 Mercury OB
Merc Trouble/Repair.
