Gimbal bearing came out with the drive shaft
matt167
Pulled the motor from my 2nd parts boat to swap in the SC since it’s better… the outdrive didn’t come out so easy and when it did come out, the gimbal bearing is galled and seized on the driveshaft… anyone ever see that before? I know that I didn’t put enough pressure to actually pull the gimbal it had to be somewhat loose
Scott06
It’s rusted to the driveshaft not loose in gimbal housing. Typical of boat that have had water in bellows and sat
matt167
Gimbal did have a little water in it so I guess no surprise.
