Re: Gimbal bearing install.... Is there a wrong direction??
Mercruiser wants you to install it per the bulletin so you can't remove the bearing from the cartridge, which you don't need to do anyway if you have a grease zerk on the gimble housing. If you don't have a zerk on the gimble housing,,, how are you going to grease the gimble bearing? I doubt the OP needs to install it facing aft, though, we don't know what he's working on...
I do agree that the cartridge should be replaced along with the bearing, as Mercruiser states. The service bulletin is their way to MAKE people replace the cartridge with the bearing.
