Gimbal Bearing Installaion
Josh P
Ok ive searched for a while, no luck... what is the proper postioning of the gimbal bearing? The dot on the outer ring facing out or the slots facing out? I know to line up the grease hole. when i took my old one out the slot6s were out.. found some hacked stuff on this rig, just wanna make sure im doing it right.. thanks
matthysone
Re: Gimbal Bearing Installaion
Small grease holes on outer race need to line up with the grease channel in the housing. Holes go forward.
Josh P
its small and when i zoom in its blurry.. try again for me please
Josh P
ok thanks man, ya i read that post a week ago and forgot about it.. thanks again.. hopefull going boating next weekend... dont wanna endure the ramps for the first time with this boat on a super busy holiday weekend..
so that would mean the dot faces out then.. thanks again
matthysone
dot would face forward, closest to transom. Or furthest away from installation slots. dot being on outer race where grease enters bearing.
makonnen
New gimbals are sealed bearings ... they come with a security-torx driven block off to replace the grease nipple.
