76SeaRay
- Aug 24, 2017
- 1,071
After a lot of research on gimbal housing castings, here is a chart that I have created using the info I found. I believe that to convert from 4 bolt offset Y pipe bolt pattern to the 5 bolt pattern compatible with newer Y pipes with non-offset bolts, the 42559-C casting was created by Mercruiser in the transition period (89 to 91) of Alpha One Gen One to Alpha One Gen Two to satisfy old and new Y pipes. Looking for comments and feedback on this chart. I will update it with corrected or additional information if anyone has more info.
