Thank you for reply. The gimball ring is the correct ring based off of S/N.
Theory: There was enough wear in ring top and bottom of ring to give the outdrive a more negative trim in angle, kind of masking the true trim in range. Also, the props that were used were worn michigan props! Correct pich, but worn. Could a prop chang the attitude of the boat?
If you are adjusting the trim by gauge alone, stop it. Trim by feel of the boat. You just have the gauge adjusted different. You can't get that much movement in a worn gimbal ring to cause that.
The prop is NOT your problem,
