I have a Volvo Penta 5.7 mid 80's with a 280 outdrive. <br /><br />Yesterday I was coming in from fishing and the outdrive made grinding noise. <br /><br />Long story short. I removed the upper drive assembly today and looked into the flywheel cover and the balls for the bearings were everywhere. It got dark so I stopped. <br /><br />These are the bearings that ride around the drive shaft or gimbal shaft whatever you call it before it get to the outdrive. <br /><br />My repair manual does not help much, it does not even mention the flywheel cover in the V8 section??? <br /><br />My main question here guys is do you have to remove the engine to do this? <br /><br />Any help or advice will be appreciated
