97_Manta_Ray_CR
- Jan 19, 2015
- 67
I am in the process of greasing up the fittings on the outdrive and I need to know how much grease is enough for the gimble bearing grease fitting I put about a quarter of a tube of grease in that fitting the other night is that enough or should I put more?
Also I am having an issue with the trailer button on the shifter... I press the button and the trim pump clicks but nothing happens now If I press the trailer button and rotate the button around it will finally raise the lower unit.
Any advice on either one of these questions
Thank you
Chris
Thank you
Chris
