How tight should the GImble bearing be on the drive shaft? I am installing a new gimble bearing on a OMC cobra outdrive and it feels almost to tight. It does not readily slide on all the way up to the o-rings. The shaft had been sitting in water but I cleaned it up very well and there is no longer any service rust on it. It just seems like it almost needs to be pressed on the shaft and I know that's not the case.
