gimble bearing
HI folks, <br />Interested in talking with anyone with mercruiser 898 out drive experience. I have a 79 Webbcraft and I am changing out the bellows, U-joins, impeller, and gimble bearing. <br />I am concerned as the gimble bearing that I received is not the same and the one coming out of the boat. Could the parts people have sent me the wrong one, or do take parts off of the old one? Confused amateur
Laddies
Banned
Re: gimble bearing
They should not have the only other one was used in the early units of the 60s, thats your part number
cc lancer
Re: gimble bearing
The bearing was improved about 10 years ago, if the directions did not come concerning placement<br />of the bearing let us know. :)
Re: gimble bearing
The bearings themselves look the same, but it looks like there is a housing around the bearings. The bearing came in a kit, and has the numbers BBY-5536
Re: gimble bearing
I also looked at another posting which stated that the bellows replacement and water hose replacement is really difficult without a special tool. Is this true?
tommays
Re: gimble bearing
http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=010458#000000 <br /><br /><br />i just did mine on a GEN II drive i would say its a pretty hard job <br /><br />i found the water hose to be the hardest part<br /><br />if your willing not to rush through it its not that bad <br /><br /> i spent a coupple of days doing it very slowely you have to really take your time because if it leaks you wont find out till it damages other parts <br /><br />a merc service manual is a must and you do need to use all the correct glues ,sealers and other things in the manual<br /><br />tommays<br /><br /><br />
steve n carol
Re: gimble bearing
DonS posted a link to another site which addressed this very topic. in it were included pics of the NEW style bearing and it's installation proceedures, this was about 2 months ago. you can search the archives, in this forum. Go find it...you'll be a happy camper!!!! Thanks Don..sl
steve n carol
Re: gimble bearing
Tommays, I just saw the 'first aid kit'. thanks for the GOOD laugh!!!sl
RAPIII
Re: gimble bearing
I did something very similar to you, bought the u-joint bellow, exhaust bellows, gimbal bearing shift cable bellows, and a myriad of other parts. Went to work pulling everything off, and then dragged her to the shop to get the guys there to put everything back on. $500 later and I am one HAPPY HAPPY man.
Re: gimble bearing
I Always recommend an Economy Sized Box of Band-Aids..... <br />And,.. Paid Up Health Insurance......... Just in case it get's Nasty.........
Re: gimble bearing
Bondo,<br />You are so correct. I finally got fed up with being nice to this contrary Gimble bearing. Using a large vice (might have been smarter to use another vice like alcohol, say Jack Daniels) I beat the living daylights out of the thing. Only one blow to the fingers, but the tennis elbow is going to require the latter vice to mend. Thanks for your advice. I have removed the gimble found a nice bunch of rust, and glad I did not run the boat in the poor condition it was in. I think it might have self destructed upon reaching operating speed.
qaztwo
Re: gimble bearing
I did mine for the first time, about a month ago. Took me a whole day mainly because I didn't put the bellows back on in the correct order and couldn't tighten one of the bellow's clamp, and had to redo it. Also I had the whole assembly off the boat and still a pain.<br /><br />With that said the bellows and gimbal bearing costed under two hundred dollars, add one day to change them and money well spent.
