Gkuing ABS plastic to fiberglass gel coat.
model14
I want to glue thin 1/8" ABS plastic panels to a sanded gel coat surface in the interior of my boat. I don't know if the ABS glues will stick to sanded gel coat. Any experience in this?
Thanks,
Richard
Re: Gkuing ABS plastic to fiberglass gel coat.
ABS doesnt stick to much. check with your local 3M representative.
Bob_VT
Will not happen....... whatever you are installing needs to be screwed on or riveted or placed behind some strips of wood or metal....
model14
Okay, thanks for the info.
