nola mike
- Apr 22, 2009
- 5,695
Finally got around to winterizing the boat last week (I actually STILL thought about taking it out that day). Have had a leak at the exhaust manifold/riser junction because of a bad surface on the mani, so I had planned on machining it before spring. Got it started with a bit of difficulty after 2 months, but it was running. Pulled the riser/mani, and pulled the valve cover just to take a look. Glad I did. Plan on replacing the spring guide and spring. Any thoughts on what would cause this? Haven't messed around with the valves with the head still on. I don't have a fitting to attach the compressor to the cylinder--could I prevent the valve from dropping just by moving the piston to close to TDC?
