Glad I pulled my engine
metsfan3197843
Was a little hesitant to pull the motor just to clean things up and look things over but I’m glad I did. I could poke my finger through if I pushed real hard🙈
achris
More fish than mountain goat
Yep, steel sump + seawater = "I need to weld up the holes"....
Weld it up (or replace it) and before you paint it, get it hot dip galvanised...
Chris..........
kenny nunez
Take a close look at the timing cover. The area under the harmonic balancer was never painted. Get a new one. Powder coating is also a good way to protect the sheet metal parts including the valve covers. Are the belt running surfaces on the pullieys in good shape?
metsfan3197843
I’ll probably replace with new. Anything special about a mercruiser oil pan and gasket or can I reach into the automotive world for better pricing?
Bt Doctur
Auto should be the same, but add a coat of paint when assembled and some undercoating
Lou C
I've sprayed my pan, timing cover etc every few years with Boeshield T9 or Corrosion X. So far so good, even in a 100% salt water environment kept on a mooring....15 + years worth....
metsfan3197843
Corrosion X HD is some pretty awesome stuff in applications where a thicker film is an acceptable use.
Anyone have any experiance using the Sierra oil pan and gasket? Good or bad?
