screwloose
- Aug 12, 2012
- 38
I looked at an older 15' Starcraft boat yesterday. The last owner replaced the deck and transom. He's a body guy that specializes in fiberglass truck body repair and trailers.
He did the job where he works. He's got pics of the whole repair. The deck looks fine, he removed the old wood, there's no flotation under the deck, just glass tubes or stringers.
He cut and fiberglassed the new 1/2" plywood with two layers of glass mat on both sides and resin, then glassed the new deck in place feathering the edges into the sides of the hull. That part looks great, it just needs to be painted.
On the transom, since the outer skin had torn away, he worked mostly from the outside. He cut away the area where the motor sat, he dug out all the old wood, ground the surrounding glass a bit and proceeded to lay up a new transom using both glass mat and recycled fiberglass trailer panels and mat. The result is a rock hard solid transom but I've just never heard of this being done before?
I'm sure it added some weight but I doubt its all that much on such a small transom. The solid glass area is about 57" x 15" x 1.5". He left the original corners intact and worked around them fitting the new panels and mat in behind the uncut sections of the outer skin. Other than the lack of an aluminum transom cap, you can't tell by looking at it and the 33hp motor on it don't budge.
My question is if this is an acceptable repair? Does it sound like a repair that will last? My concern I guess is the thickness of the entire glass panel now. I have little doubt about the rear panel being cut, he had no choice since the motor basically fell off tearing the transom rearward.
He also didn't try to hide any of the past repairs, if he didn't mention what was done or show me pics, I'd have never guessed it. I'd probably have assumed it was a poured transom.
