Hey guys,
I recently decided to undertake doing my transom. My boat is a 13.5' sunray year is unknown to me. IF someone can give me some idea of this would be appreciated. I first separated the hull by taking the top off. I had to cut slashwell as it was fiberglassed to the transom. Hope That's ok, let me know if it is. I took the inside skin off and found my rotted transom. It was a rough sawn piece of lumber which makes me think it isnt original.It was 21/2" thick. I have it all cleaned out with the outside skin still intact. I have laminated two pieces of 3/4" marine plywood with epoxy. Now I need to place in transom area my questions are as follows. Do I epoxy the new wooden core to the outside skin with just the same thickened epoxy mix that I laminated the ply together with? Or do I use something different? Next I need step by step instruction on filleting and how to glass it in for strength? Please help. I have 6oz mat that a marine shop said will work. Hopefully someone can help.
Thanks
Thanks
