F14CRAZY
Ensign
- Aug 12, 2008
- 945
http://forums.iboats.com/showthread.php?t=272749
My primary rebuild thread is above.
When I get my stringers all done, what can I do to the plywood to better protect it? I want to call it the deck but it's technically the "sole", right? I do intend on putting a layer or two of fabric on top w/ epoxy but can you do anything to the bottom side to better preserve it? Like use penetrating epoxy? Or put a layer or two of glass on it before screwing it down? Should I use penetrating epoxy on the topside too before adding a couple layers of fabric?
I understand the idea of predrilling holes larger, filling with epoxy, predrilling again, and then screwing the deck down, but would you put some peanut butter between the top of the stringers and the bottom of the decking?
