Hi Guys,
I'm brand new to this so appologies if I have posted in the wrong area
So my problem is that when I push in the small button in the center of the gear shift it gets stuck in.
Typically I would push it in so that you can rev the engine a little without the prop turning, for example when you first start and warm up the engine.
When this button is stuck in you cannot select any drive gear, effectively the boat is stuck in neutral.
I have tried wd 40 and crc ect but it feels like it is stuck in, that is not springy when you push it.
Any advice and comments would be greatly appreciated......Cheers
