Glastron stereo
Doug Kenyon
I have an 08 glastron 185 ski and fish. Hit a wave pretty hard and the stereo quit. There's a fuse off battery that is labeled stereo memory, it is fine. A fuse on back of stereo that is fine. There's no power to stereo or switch by drivers seat. Any ideas?
Thanks
09TNRT
You need to check the wiring coming from the ignition switch. The memory wire just holds your presets, should be yellow on the radio. The ignition turn on wire should red on the radio. Trace it to the ignition switch and start there. Check whatever the radio is grounded to as well.
Doug Kenyon
Thx. I found the issue. One out of the three wires on back of switch by drivers seat came off.
