Glastron vagabond camper prop size
Coffeecup
Hello I'm new to iboats. A friend said yall can help. I had a 1977 glastron vagabond camper boat given to me, it's up and running and is a solid boat in very good condition but the prop was missing. And I can't find what came on it for sure.. it's eather a 15x15 or 15x17 LH long hub... can anyone help
Ayuh,...... Welcome Aboard,...... What motor,..?? What drive,..??
NYBo
Are you sure of the model year? The iBoats boat specs area only lists the Vagabond up to 1975.
Anyway, this looks to be a rather heavy boat for its length so chances are, a 15x15 prop would be more appropriate than a 15x17.
Coffeecup
Thanks Bob, and yes according to the hull numbers and registeration it's a 77 model ....I'll go with a 15x15
Ayuh,.... I think those ole Volvos will turn either direction, by just changin' the shift cable to a different attachment point,.....
Right handed props are common,..... left handed props are reasonably rare,....
This +1
