Glove Box
Hislopy
Hello, I was wondering after i cut my hole out of my center console, should i seal the wood with something before i put my glove box in? If so what do i seal it with? Thank you
Bob_VT
Re: Glove Box
Welcome to iboats.
Absolutely seal it up. You can paint the exposed with with a bit of fibergalss resin or even coat it with some 3m5200 caulking. The trick is to seal it from the elements. You could probably mix up some jbweld and coat it with that ...... please just do not use any silicone because it will not last.
