gluvit pro's
shipwrech
so bought and applied some gluvit about 2 weeks ago, worked fine, now I opened the can to mix some more and its really dark kinda brown. I don't remember it being that color before. am I retarded or is something wrong with it? Thanks
nowback
Re: gluvit pro's
I have not used the stuff but i think its a one time thing you have to use it
all up once the can is opened.
it might say that on the can?
matt
Bob_VT
Re: gluvit pro's
It is normally a dark amber color. As long as you do not mix in the catalyst it will last a LONG time.
Do not let color bother you. Any exposed gluvit that is in the sunlight on your hull needs to be painted anyway since it is an epoxy and does not have UV inhibiting properties.
You are okay :)......... it is NOT required to mix it all and use it right up and at $50/two pound can I hope not!
shipwrech
Re: gluvit pro's
ok good cause I bought a gallon and have only used about a third of it.
