Gm 5.7 lg sgi
Rranger
My motor has GM 5.7LG SGI with 14093638 engraved on the block. I've looked for a serial number, told its by the back of the starter, no luck.
Can anyone out there tell me the year and if there is any other "hidden" serial number on it.
Many thanks for any info about the motor. Would pics help?
Lyle29464
Re: Gm 5.7 lg sgi
The number you have is the casting number. My book says 87-95 one piece rear main. I think that is all you can get from that number
Don S
Re: Gm 5.7 lg sgi
Post some pictures, year of the boat, lots of ways of getting close to what you have.
Drive or better yet transom shield serial numbers could help as well.
Rranger
Re: Gm 5.7 lg sgi
Grand Forks-20130214-00116.jpgGrand Forks-20130214-00118.jpgGrand Forks-20130214-00121.jpgGrand Forks-20130214-00122.jpg
Here are pics of the 5.7 LG SGI No serial number wondering about the age. I know nothing about the boat it came out of. Pics of the housing and the label on the outdrive marked 888. I plan on replacing the motor in the next set of pics with this.
Rranger
Re: Gm 5.7 lg sgi
Next set of pics my future boat.
I'm hoping to pull the motor with 228 stickered on the valve cover out of this boat and put my motor in the above set of pics into this boat. Can do a total replacement but hoping above motor bolts up to the housing already in the boat. Any chance of that??
Couldn't get a number of this outdrive its gone.
Re: Gm 5.7 lg sgi
View attachment 181927View attachment 181928View attachment 181929
Ayuh,... You might be able to put that motor in that boat,...
The Problem is gonna be the Drive,..
It's a TR/ TRS drive,...
It's antique, 'n parts for it are very, Very limited....
Rranger
Re: Gm 5.7 lg sgi
So am i better off with the 888 outdrive?
Re: Gm 5.7 lg sgi
Ayuh,.... Atleast you can buy parts for it....
The TRS drives don't shift, 'n have a transmission mounted ahead of it,...
The transom hole is also bigger...
It's a very heavy-duty drive, just hard to get parts for...
Rranger
Re: Gm 5.7 lg sgi
Is the transom hole going to be a issue when I remove every thing from the boast and install the 5.7l and the 888 outdrive?
Re: Gm 5.7 lg sgi
Well, as I said, It's BIGGER....
The 888 Ain't gonna bolt in, til ya refill, 'n recut the transom....
Mercruiser sells a filler plate, but it ain't cheap, 'n doin' it with plywood is a 'ell of alot cheaper, but more time consumin'...
Rranger
Re: Gm 5.7 lg sgi
Thank you not up on this stuff so rely on your advise. Thank you.
Rranger
Re: Gm 5.7 lg sgi
One more question, is the lower unit casing in the picture of the the one attached to the boat interchangeable with the lower unit on the 888 outdrive. And if so the inside parts must be interchangeable? My 888 lower unit has a crack right through behind the zinc trim anode. Hoping to switch. Welding is a last resort.
Re: Gm 5.7 lg sgi
Nope,.... Night, 'n Day different drives....
Rranger
Re: Gm 5.7 lg sgi
I have access to a Izuzu diesel. that has a older (1985ish) 280 Volvo leg outdrive on it. Motor needs maintenance but probably worth doing. Question is does the 280 Volvo outdrive have the same transom hole as the TR/TRS??
Rranger
Re: Gm 5.7 lg sgi
preview001.jpgI have this x dimension template, Can I use it for my mercruiser 188 outdrive? And I'm not up on blowing it up and having it printed. Do i need to know a size to have it blown up to when i get it printed..? If so anyone know the size? Thanks for the help..
Don S
Re: Gm 5.7 lg sgi
That's not even close to the right one. That's for a Volvo 270 to 280 Way too big of a hole.
Merc doesn't seem to have one anymore, but the Volvo SX cutout is the same, and you can get their templates.
7745528 - iboats
Rranger
Re: Gm 5.7 lg sgi
7745528 - iboats
Yup after I sent this message I got to my shop and measured and definitely the wrong one. Ordered the one you said today. Thanks.
