1998 305. Is there an automotive part that will work for me. My merc unit has failed. Thanks
S scoflaw Ensign Joined Jun 2, 2010 Messages 962 May 1, 2011 #1 1998 305. Is there an automotive part that will work for me. My merc unit has failed. Thanks
D dubs283 Vice Admiral Joined Jul 27, 2005 Messages 5,337 May 1, 2011 #2 Re: gm oil pressure sending unit why cant you use a mercruiser part??
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 May 1, 2011 #3 Re: gm oil pressure sending unit All you have to do is find one with the same resistance values to work with your MARINE gauges.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,148 May 1, 2011 #4 Re: gm oil pressure sending unit 305 efi Click to expand... Ayuh,... Being a 'puter controlled motor, I'd use the Right sender...
