gman57
gfb220
Help please Im trying to find out what other lower units are compatible with a 1964 9.5 hp Johnson, thanks .
Up to 73 is a straight swap out.------Some of the 10 hp up to 63 units will also work.-----But you need to understand which ones have the splined pinion.---Also shift rod is longer.----The 10 HP driveshaft is longer.------Lots of these units around in some locations.----Your location ?
