I took my newly owned boat out this weekend and my worst fears came true. I went aground. I was in unfamiliar waters at low tide. Fortunately, it was a sandy bottom and I was going slowly. I was able to get off fairly easily. The water temperature was 43 degrees so jumping in to push off was not an option. What is the usual case regarding which part of the boat gets stuck? Is it the hull under the bow or the outdrive (my boat has an I/O). Should I have shifted my weight towards the bow to raise the stern of vice versa. As it turned out, I was able to tilt the lower unit up and back out. It was a great lesson about the need to know exactly where you are at all times. I was only 50 yards form the channel, but not close enough.
RK
RK
