I have a 21' Center Console boat, the lower unit had hit something when I bought the boat, so it was already destroyed. I bought one on eBay (1982 115HP mercury). The description stated it had a 25" shaft.. same length has the one I removed. But when it got here, it was just 20". When I removed the lower unit, there was a spacer per say between the lower unit and the power head as the shaft was longer. I can put the lower unit in without that spacer. I'm trying to find a picture of how far the prop was below the boat and if 5" will make a huge difference.
Any suggestions? I can't switch the two shafts out because the 25" shaft has butchered the splines up from whatever it hit.
Thanks!
Thanks!
