Re: Going from alum to S.S. prop
If the SS prop has hgiher tech features, it may run higher RPM due to more lifting capabilities, which will equate to more speed.
If the hull does not react in a positive manner to the extra lift, it will likely be just a tad faster at mid-range, but lack about 100RPM from the alum prop.
Speed will likely be about the same even with the 100RPM drop due to a more efficient design at the same RPM..
Alot depends on the SS prop choice.
