Going to change out fuel pump diaphram, why should i try and brake platic thingy then
199675hpforce
reinsert the broken plastic back in check valve? Im worried about doing this as it might damage the plastic clear thingy. The last time i did this i belive i just cut the white insert with razor then poped back in.
wayne h
Master Chief Petty Officer
Re: Going to change out fuel pump diaphram, why should i try and brake platic thingy
not sure what your asking here ???..but if it broken replace it
199675hpforce
sorry on my square fuel pump
they tell in the instructions to brake the stem while inside the valve i could get it to brake while wiggling and backed off cut that sucker with razor taped it back in.
