Re: going too fast on tickover.......
That seems like an awful lot of prop for a 4 cylinder, what is your wide open throttle rpm's.<br />If they are to low, you may be overloading your engine big time which will cost you an engine.<br />Overpropping would also cause you to go faster at idle, but make it slower getting on plane.<br />You should be around 44 to 4800 rpm's at WOT and have an idle rpm of 65 to 700 rpm.<br />What are you idleing at now???<br />That could be part of your clicking while shifting problem.<br />Can I also assume you don't have the electric shift? You never said in your other post.
