gunner1
- May 13, 2006
- 375
I have the Clymer manual and the rebuild seems pretty straightforward enough, but I noticed that the manual talks about a spring that should be in the bowl for the main jet, yet this carb doesn't have one. I thought maybe the previous owner had lost it, but when I took the carb off of my spare 1990 50hp, it didn't have the spring either. Are the any pitfals I need to avoid. I decided it was time for a rebuild because I noticed that fuel was dripping out of the bottom of the bowl the other day. Should I redo the fuel pump as well while I'm at it? It seems to work fine since the motor starts and the fuel bulb holds pressure.
