Thanksfor your responses!!
Ok, I believe what you are all saying is that most V4 crossflow internal parts (ie. crank, rods and pistons)parts are interchangeable as long as you have the correct crank seal assembly for your model year. as long as you match large or small split center bearing crank to same style block.
Can you take a small center berring crank (ie; 1977 or earlier) and put a large center berring on it?
Do I need to use the original upper and lower crank bearing assemblies from my block or do I use the bearing assemblies from a crank I purchase.
I also take it that I should use all of the original carbs and intake to the supply the needed fuel as well as the original flywheel and ignition components.
You are also saying that HP output of my 1984 140HP is the same as a 1995 115HP because the HP is rated at the powerhead vs the prop for later models.
What are your thoughts on after market pistons Vs OEM.
I just want to say thanks for all of your help, it is greatly appreciated!!!
Thanks, J
Thanks, J
