good deal gone bad
Kent Myers
i am about ready to give up on my boat i thought i made a good deal on it but its been nothing but trouble and i have not gotten to enjoy it well my 85 hp johnson is finally running great but now i have a problem with my trim works fine on the bank but in the water at wot it will not trim up and i cant run it and have fun because it jumps in and out the water like a dolphin
littletunny
Re: good deal gone bad
has the trim worked before?
when?
does it move at all?
do you hear solenoids clicking or the trim motor running?
Do you see any leaks at the trim cylinder?
tashasdaddy
if it is porposing it is too trimmed out too far, bring it back down. on my boat i only have to trim out just a tiny bit. to get top performance.
Hoss 350
Poor bugger. Nothing worse than having a piece of recreational equipment giving you fits. They are supposed to be fun, not a pain in the arse.
That being said, your porpoising problem is likely not a function of not being able to trim UP, but not being trimmed DOWN enough. I wonder if there are adjustments on the transom where you can bring the bottom of the motor in (down) some and see if that helps?
To your trim problem, it being able to work on land but not at sea leads me to suspect that soemthing is weak, and the thrust of the motor is overpowering the trim motor. I cannot help you with that, unfortunately, I know little about them and this is just my suspicion. Best of luck with your troubles.
Kent Myers
well it has not worked since i bought it but it does work rine on the bank or at low speed but when i put pressure on it it will not pick up and the motor is all the way down so that is not making it jump it needs to come up and it has no leaks can the fluid be bad or the motor ?
tashasdaddy
fluid could be low. what year 85 is it.
jbjennings
Kent,
Is your cavitation plate level with the bottom of the boat when all the way down? If not, then it's not down far enough. It won't porpoise from being down too far, just being up too far--as was said earlier.
I hope you check it's position again. there may be a pin or bolt you can move to a lower position to get it down better and prevent the porpoising. If it's porpoising and you actually do get it to trim up, the porp. will get worse, not better.
JBJ
Kent Myers
thanks guys took your advice and trimed it down and it runs great i guess i was just a big dummy and didnt know what i was doing
iwombat
Everyone else here (myself included) know EXACTLY what we're doing ALL THE TIME.
Happy boating.
