Lou C
- Nov 10, 2002
- 13,062
OK seriously thinking of re-powering my old boat over next winter, from the 4.3 V6 to the 5.7 Vortec. Question is, the Cobra drive system I am using (I have a good original drive and a good spare) uses a 1:68:1 ratio. Will this work well with a V8 if I go to a larger pitch prop? I had used both a 15x17 and a 15.5x15 with the V6 to lessen the strain on the V6 since I think the boat is really a bit on the big/heavy size for the V6. Also, from some investigation it appears that you can't get new base 4.3 Vortecs any longer. Would like to start with new and it appears you can still get new 5.7s either Pre-Vortec or Vortec. Thoughts? if I go with a larger pitch prop will that gear ratio work out? OMC used 1.41:1 for the 5.7s, and a 1.50:1 for the 5.0s.
This boat was definitely available with the V8 from the factory and the engine mount pads are more than long enough. I know that keeping it with a V6 would be the least expensive option since less other stuff needs to be changed but if I'm doing it I would like to have the power the boat deserves.
