acdc96
- Apr 23, 2013
- 412
Last week I took my 14' alumnium boat out of the water. The ramp I used is only accessible during water foul season (winter) it's a small dirt ramp that is back in the woods. Must have 4x4 to go back their or will get stuck. I got the boat on trailer and started heading out got to the top put the transom strap on and started leaving. I turn the corner to leave and the trailer didn't turn the way I planed on and it went into the bushs. I hear a thud but everything looked fine and went home. while emptying the bow compartment i saw daylight coming out the side!! i look on the side and theirs a 3 inch tear 5 inches above the water line. It looked like someone used a box cutter and sliced it open (no one did) I guess the the thud was a tree or debri in the bush.
I plounded the tear flat and was going to see if I can fill it with some aluminum brazing rods but could not get the alumnium hot enough to melt it. I tried using propane and mapp gas.
My plan is to get a thin sheet of aluminum (maybe 21 gauge) and make a 4"x4" square and pop rivet it on with some carb gasket material & 3M 5200. With the rivets being 1/4" apart from each other (16 rivets perside)
thoughts or better fix?
