Got Boat Started won't shut off w/ key
MikeM40
Must people write in they can't start the boat mine started but doesn't want to shut off
Got the boat started no problem but went to shut it off w/ the key and nothing. Do I need a new igntion switch?
I had to pull the coil wire to stop it. Its a Merc 3.0 inboard
Any help would be great
TIA
Bt Doctur
Re: Got Boat Started won't shut off w/ key
Any chance you just replaced the alt.?
MikeM40
No Bt its the same alt
The belt was alittle loose
any other ideas?
bruceb58
Easy enought to test...after you start the engine, pull the main power wire off the back of the ignition switch.
MikeM40
I pulled all 3 wires off the igntion switch and the boa was still running.
Someome mentioned there may be a relay that may be stuck closed.
