Lou C
- Nov 10, 2002
- 13,201
Hello iboaters,
Well my old '88 4.3 finally acted up in a big way. Its been in salt water raw water cooled for at least 15 years. I'm posting this here even though mine is an OMC boat because you get more traffic here, lol. What happened was this: difficult starting, rough running and after some diagnostic work I found water in cyl #2 (front starboard side). Yes salt water. I tried a spare ex manifold I had and it was not from that so I knew it was internal. I pickled the engine after draining all the water out. I just took it apart (not bad really, the intake removal was harder than the cyl heads). The engine spins over easy and there is no rust or scoring in the cyls. The head gaskets to me did not look blown. I think the valve guide area in the head rusted through. Question: is it worth it to try saving this one by bolting on a set of rebuilt heads, or is the block likely to be just behind the heads in terms of potential rust through? I have a few options beside that. One is to get a reman non vortec 4.3 from MM and use my old intake which is fine still. The other is to up grade to a vortec 4.3 with MM's partial engine package and add closed cooling (much more $$). Want to keep the boat just need some guidance on the best (not necessarily cheapest) course to take....
You can click on the full size pix for details...
