By default my garmin chartplotter takes position data in the following format<br />N 27' 59' 19.6<br />W 080 38 51.7<br /><br />But Top spots charts gives a position like this........................................ <br /> North West<br />28' 37.46 80 25.30<br /><br />So what position format should I be using to match the top Spots map?<br />As you can see the number of numerals is different. Obviously W80 is the same as W080 but you are still dropping the last numeral that comes after the decimal point at the end of each lat/long. So it seems the numbers need to be converted or the format changed on the GPS unit?
