20' center console with a custom hard top (ss tubing and fiberglass top). plan on purchasing and instaling a garmin gpsmap 162.<br /><br />i was set on buying the unit with the external antenna and throwing the antenna on top of the hardtop. but looking at the tube running from the elctronics box to the console, it doesn't look like i can fit the fish the cable through (already filled with power lines). i may still try but will be stuck if i can't.<br /><br />other alternative is to purchase the unit with the internal antenna. anyone have an opinion/experience with this? will the hardtop block/degrade signals? i've used an old handheld under the top and it seemed to work fine. don't want to get bad signal strength and disable the waas. thanks-
