LX Kid
Ensign
- Sep 5, 2008
- 993
My '82 GW has two fuel tanks in the floor and the foward flooring tank cover was spongy. Removed it and found the underside fiberglass had failed and split open. Cut out damaged f/glass and found wood "wet." Don't even want to think about how water got into it cause you'd think the boat would have to be sitting under water. Question is why did they make the tank cover useing 6x6 inch squares of plywood instead of solid sheet of plywood?
